Results 1 to 15 of 23
    Dec 2018
    Latvia
    Default VW Touareg Key Programming problem,
    Hi guys. got a VW Touareg 2007 with key PCF7946, order a key with number 3D0 959 753 P like on car, get out kessy ecu, read eeprom, and make key by dump in tango, all good. Write back dump to kessy and go test on car, no luck original keys work, but new key not! After this i try to adapt keys by online, no luck also, after i try with Abritus, also no luck, original key wrote back new one non, when i go inside abritus to test what is going on, then new key tell me, DEALER KEY Status = OK, TRANSPONDER TYPE = OK, KEY STATUS NOT LEARN, i order key from a https://www.car-keys-online.com, hope maybe some one can help me to get deal with this car, if need i can give VIN number, and what key i can order second time because 3D0 959 753 P is really non cheap key, maybe some different number?
    Dec 2018
    Latvia
    Some body??
    Sep 2016
    Some china keys have very week coils.
    Dec 2018
    Latvia
    Quote Originally Posted by qeso705 View Post
    maybe you know, if different key will fit to car, because last key coast 100euro
    autochei's Avatar
    Mar 2013
    romania
    u can use kd remote
    Dec 2018
    Latvia
    Quote Originally Posted by autochei View Post
    u can use kd remote
    i don't have a KD Remote!
    Feb 2014
    Why take out Kessy and read eeprom, when you have AVDI ?!
    Not always a good idea to make car with different tools. First Tango then AVDI ...
    But if you are sure problem is not in the programming procedure, then order a key from Autokeys. Theirs are working 100%.
    And get a KeyDIY mate! It's a waste if you don't have one.
    p1et's Avatar
    Oct 2013
    Kessy is Siemens or Continental?
    Dec 2018
    Latvia
    Quote Originally Posted by p1et View Post
    i'm think its conti
    p1et's Avatar
    Oct 2013
    I think Tango don't work with Continental kessy, maybe that's why new key doesn't work. But AVDI tell you that dealer status is OK so there's confusion...
    Dec 2018
    Latvia
    Yes this is the problem, that AVDi tell me dealer key ok, but immo don't adapt it by OBD, and also no luck via dump, so my idea that Tango don't make good dealer key, also i try to made with tango on VW Passat 2010 smart key, also no luck with tango, i made key by dump then back, and after car starts working but go immo message on board. after 2 runs key not work, then i made key with AVDI, and all good strange!
    So to try another key, what number can fit, don't wanna order again for 100euros!
    Feb 2014
    Already told you about the key. Just order a Touareg key from Autokeys. These keys are among the cheapest in our business. With 100 EUR you can buy 15 not 1. Maybe you've been scammed and you should ask for a refund! And use AVDI by OBD next time. No need to go deep in eeprom for this car.
    If you have doubts in Tango you can always contact Lyubomir. He will help.
  13. #13
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by AndrewStone View Post
    Just replace PCF7946 to new one.
  14. #14
    Dec 2018
    Latvia
    what about a radio channel, will it work?
  15. #15
    Dec 2018
    Latvia
    can some one help me?
