Results 1 to 6 of 6
    Feb 2010
    Poland
    Default EDC17CP14 delete dtc.
    Please delete dtc P1028, P319E or swirl flap off. Thanks
    Sep 2019
    Hey, bad upload of your rar.
    Dec 2010
    I don't see P319E in your ECU file anywhere.
    Feb 2010
    Poland
    Do where problem? Vcds sat this dtc...
    Dec 2010
    See if there is another code for it, maybe a 5 digit VAG code.
    The ECU should have a full list of all the P codes it can use and store.
    When you find the complete list of DTC names, you can disable the DTC switches by counting how far into the code table your DTC is.
    If you have the 63rd DTC, then you change the 63rd switch to 0 and the code is off, but if the DTC can't be found in the table, you can't identify which switch controls it
  6. The Following User Says Thank You to Morette For This Useful Post:
    radoslawwiklik (20th September, 2019)
  7. #6
    Feb 2010
    Poland
    Vag code is 004136 and 12702 but also dont see in the file...Who has idea?
