When showz 2-0 put the key neaer coil on the standard place wher is ignition lock
Wysłane z iPhone za pomocą Tapatalk
I have an 2010 Golf 6 R with keyless system.
I tried to add a new key to the car using FVDI.
Now the car shows 0-2 on the dashboard and i cannot add the keys.
I tried adding only the original key and same problem , it shows 0-1 and "key not found"
Is there a special procedure to add the key different from a normal car without keyless ?
I tried that but it doesnt work.
strange - wonder if issue with car's key coil .
Try one of those coil testers which light up on signal - avdi sell one.
The car worked perfectly before i tried to add the second key
Did you do backup of dash before hand?
If so restore it.
In theory it could be left without keys as needs to 1st see the key near coil to register.
I did not do a backup because i didn't open the instruments.
You can do backup on all systems, even MQB systems, without opening dash. Indeed VVDI even pops up with a message saying "do backup"
FVDI is from fly - so recommend a decent tool like AVDI or VVDI, and bin Fly
Good luck
Try go go in measuring blocks in immo.
Check if ignition coil is working by checking the key..
Avdi add support for keyless very late, fvdi probably just dont support it.
I cannot measure blocks in immo, it's grayed out.
I measured the coil on pins 7 and 8 from the instrument cluster and it has a resistance of 86 ohm.
I noticed that if i press the Start button the led on the key blinks for 1-2 sec , than the "key not found" message appears
Hi, sure fvdi damage the immo data of dash, need repair the data manual & after you need vvdi2 to continue...
Read pin-FVDI and then use ODIs to add the key.
Press Thanks and Reputation
