Results 1 to 11 of 11
    Sep 2019
    Default Fiat Croma 1.9 JTD 150ps swirl flaps delete
    Hello
    Dump read by MPPS.
    I need DTC P2008 AND P2014 deleted as swirl actuator is removed.
    Thank you
    mancioks's Avatar
    Feb 2017
    Germany
    Try this one file. pass pm
    If i helped, don't forget push thanks + rep
  3. The Following User Says Thank You to mancioks For This Useful Post:
    cromek1976 (19th September, 2019)
    Sep 2019
    I Will try tommorow :-) Thanks
    Sep 2019
    Your solution does not work.
    1. Cant delete P2014
    2. P2008 does not show and that is OKAY
    3. P0401 EGR Valve error appear....
    4. P0093 Fuel pressure error appear..
    I flashed back to stock and its okay again. P2014 and P2008.
    mancioks's Avatar
    Feb 2017
    Germany
    try this one. same pass
    Sep 2019
    Unfortunately the same.
    P2008 is not there.
    P2014 pop ups second after clearing
    After 2 min of idle P0401 and P0093 pop ups...
    pike's Avatar
    Sep 2013
    I can...
  9. The Following User Says Thank You to pike For This Useful Post:
    cromek1976 (20th September, 2019)
  10. #8
    Sep 2019
    Pike if you can help that would be highly appreciated :-)
  11. #9
    pike's Avatar
    Sep 2013
    Arrow Fiat Croma 1.9 JTD 150ps swirl flaps
    Here your Swirl off file
  12. The Following 2 Users Say Thank You to pike For This Useful Post:
    carbon7319 (20th September, 2019), cromek1976 (20th September, 2019)
  13. #10
    Sep 2019
    I am unable to download your file pike..
  14. #11
    Sep 2019
    Pike, your solution works very good. No more unwanted DTC neither other errors! Thank!
