better is to find correct hw and sw..............only remove dtc is not enough
good morning, could you help me to eliminate dtc p2452 (differential pressure sensor open circuit) of this renault megane 1.9 dci f9qe8 no dpf, the fact is that its ecu burned and was replaced by other software and harware, and although the vehicle did not is dpf, error p2452 comes out. thanks in advance, with mtx remove not let me remove dtc. I wait for your help
need help
now my goal is to buy xp-005
who will help?
pedro333 (21st September, 2019)
First of all, thanks for answering rafal, the question is that, in principle, it corresponds to the vehicle in the references, but apparently there is a version with dpf and another without the f9qe8 engine, and I can't find a map without dpf.
sorry translate fail jjj
post picture from sticker of ecu
need help
who will help?
pedro333 (27th September, 2019)
please rafal help me if possible, i can't find a way to leave this car ok.
I attached you fot the tag of the ecu, thanks friend
