Results 1 to 4 of 4
    Port Elizabeth
    Default Audi RB8 24c08_DEF
    Hi is there some that can repair this file I got car in with DEF and Showing L4 0-1 tried to adapt cluster to ecu no go and this cluster is for this car someone tried to code key with no luck and then turned immo off to get customer away. I got CS and pin from cluster and ECU . pin:04720 CS:3ac7a1e8758f43
    Cheers
    Shane
    Port Elizabeth
    Quote Originally Posted by shanektm450 View Post
    Cheers
    Shane
    Is there no solution?
    rafal's Avatar
    UK - PL
    have you avdi?
    by obd u can do this job............
    need help
    now my goal is to buy xp-005
    who will help?
    Rito's Avatar
    AVDI not always do it, If you check dejavue do it in bench...
