see with light if the display gives information, whether it is a backlight problem or a display control mcu problem
borshch (7th January, 2021), MileageAudit5 (11th November, 2019)
Display problem. no backlight no info on display.
also I have another cluster here from 2003 Silverado. display completely out also. No backlight no data.
Same fix I have posted before, 122 resistor (1200) Ohm above the transformer.
And make sure the getter in the bottom right of the display is still black. If it is white the display has been cracked, probably by some savage trying to remove the lens with a screwdriver.
Hotwire voltage?
Bottom right of display still black?
Have you watched any of the videos on jeffescortlx youtube like I suggested years ago?
There is no magic bullet for any problems in these clusters.
Test, test, test!
borshch (20th December, 2021)
I have had the same issue before ... on the back side of the pcb you will find a row or resistors that should appear brownish and likely over used over the years. Apply new solder to both ends of these and then check the brightness. 7 out of 10 times this will cure the issue.
