dantetimoc (25th November, 2019), pcbox (5th January, 2020)
I tried to clear crash here on this partner 2016 year.
95320 eeprom inside
Same as allways.
Car is equiped with driver airbag and no passenger by original and have left and right pretensioner in belt.
Can someone check my solution, because I still have this 2 faults:
-p0698 lh rh passenger pretensioners faulty
-p0362 passenger airbag led deactivation lamp
Also tried some file from this forum which reported as 100% okay and same, also attached
hi
this file is ok
95320 ori. clear
bugarcek (23rd September, 2019)
Do you know where to look for a problem. Driver airbag is new and both belts. Where should be problem?
it turns out that this eeprom may be damaged, as it may report something that is not there, i.e. the passenger cushion
try to upload a different eeprom, maybe someone will provide a proven eeprom on the forum
95320 test.rar
p0362 passenger airbag led deactivation lamp <<< drive the van, stop and cycle ignition!
p0698 lh rh passenger pretensioners faulty (fired,triggered - is crash data) - take them out a measure the resistance coming out of the seatbelt mechanism or check condition of plugs
you almost there dont give up
br
slick
“There's nothing more dangerous than someone who wants to make the world a better place.” ― Banksy
Thank you guys for help... Fault was not mine. All in my program was okay. Problem was in right connector for passenger belt. When this was fixed all was okay, so problem was not caused by me.
well done
good evening .... on the same ecu I have this problem:
dtc crash: p06a0 / p06bo
dtc with file clear: p0698
I have already put resistors on the 2 pretensioners but the error code remains.
already tried 2 clear files.
the question is .... how come with the file crash not hi l p0698 and with the clear yes ??
if I had problem on the pretensioner I had to see the p0698 also with crash files I think ...
I attach crash and clear current loaded ..
Thanks in advance
[SIZE=3][I][FONT=impact][COLOR=#ffd700]PUSH THANKS AND REP IF I HELPED YOU !!!!!!
Don't attach resistors replace with appropriate pretensioners.
joker01 (18th February, 2022), slick_dick (21st February, 2022)
solved .... the 2 pretensioners are connected in series so by bridging with resistance only one comb does not work ...
the file is ok ....
I leave it available without a pass.
thank you
