eprom same as astra and corsa of the same year. 080
Junkyard Dog (20th September, 2019)
Is safe make odometer with upa-usb? I hear something about i must erase memory... Is this true? Read,erase,write? Safe erase?
I think meriva only via OBD doesn't have 35080 in dash
Junkyard Dog (21st September, 2019)
there is no eeprom..
its necd78...
just make by obd. any tool can do.
(press dash button during programming. after disconnect battery)
confirm as above nec obd
same as corsa
For this i have Opcom and FVDI 2014 is possible do with this tools? What you think press dash button? I must push dashbutton when i programing new mileage?Sorry for this questions but this is my first time what i do opel.
Watch this procedure, you have to do the same with Opcom, Digiprog, Tachopro 2008, Enigma and other tools.
Good Luck!
FVDI 2014 - Not working
OPCOM 8/2010 - Mileage N/A
How to do odometer?
I have UPA-USB but only green PCB what is on photo possible connect with this Instrument cluster?Screenshot_2019-09-21-16-32-47.jpg
when i change mileage by obd in corsa, i also get unknown mileage or Mileage ?????????, I only put new mileage with trip button pressed and then I disconnect battery
I try this with OPCOM 8/2010 say writting succesfuly but after disconect battery no result on dash.is possible make odometer with upa usb? (I have only this adapter see up topic)
with that, not possible
Ok...and diferent version opcom can do it?
