Results 1 to 13 of 13
    Jul 2019
    US
    Default KIA RIO 2013 US market Dashboar conversion
    Hello everyone.
    I have my KIA RIO 2013 manual tranny with the dashboard that missing temperature gauge. It's very sad. The dashboard code is
    94022-1w014
    I bought two another dashboards from cars with automatic tranny with the hope to recode them
    94022-1w118
    94032-1w018 <---supervision
    All three dashboards have the same CPU NEC d70f34 + 24c16
    The only one issue I've seen with *18 dashboard in my car the speedometer does not work.
    I flashed 94022-1w118 with the code from 94022-1w014 and got my mileage and the speedometer back, but now the suggested gear is showed incorrectly - some nonsense symbols instead of numbers.
    Does anybody have the dump from 94022-1w114 and/or 94032-1w014 or know what bit to modify to enable the AT dashboard *18 to work with MT car?
    Many thanks in advance.
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
    post a picture of your dash
    Jul 2019
    US
    Feb 2012
    Ukraine
    Try this and report
    Don`t forget to press "Thank you" if my post was helpful
  5. The Following User Says Thank You to kuzmichh For This Useful Post:
    Wiihuu (21st September, 2019)
    Jul 2019
    US
    The eeprom1.bin partially works but the speedometer showы 2 or 3 times faster speed. I can run 200 mph
    Jul 2019
    US
    Replaced 0x000 - 0x2c4 from 94022-1w014 on 94032-1w018 (supervision) and it works flawlessly!
    One tab disappeared related to the service interval but I don't care.
    I'm still looking for 94032-1w014 and 94022-1w114 dumps...
  8. The Following User Says Thank You to Wiihuu For This Useful Post:
    Killer76 (21st September, 2019)
  9. #7
    Feb 2012
    Ukraine
    I did these dumps using parts from different instrument panels. If you reduce the area of changed data, you can find a line with an coding or a few bytes of codings.
    eeprom1 - from 000 to 08F part 1W014, from 090 to 10F part 1W118, from 110 to 7FF part 1W014
    eeprom2 - from 000 to 10F part 1W014, from 110 to 7FF part 1W118
    I used a program to compare dumps: Fairdell HexCmp
  10. The Following User Says Thank You to kuzmichh For This Useful Post:
    Steve182 (4th April, 2022)
  11. #8
    Sep 2018
    How to create a full dump ? i have a dashboard from a rio 2016 940331w870 cluster vision with the lcd that not work .
    Tell me how to do i put a dump ....
  12. #9
    Jul 2019
    US
    Thanks!
    I tried to keep only one part between FFFF and flash the dash but didn't find the part that is responsible for the speed coefficient
    I deem the code is between every FFFF. My guess is that there is the piece for the general setting and there are pieces for every tab. I mean when I'm hitting "Trip" there is the portion for NEC to execute. I would like to find out the algorithm but need some hints...
  13. #10
    Jul 2019
    US
    Mine 94032-1w018 looks similar except it's for US market. I know there is somewhere the "bit" to switch it over to EU market and KMs. I found one guy who could modify the dump but for Hyundai Accent. He rejected to help even for $
  14. #11
    Jul 2019
    US
    Quote Originally Posted by alba2 View Post
    I used CH341a with the clips to read/write 24c16
    What exactly doesn't work?
  15. #12
    Sep 2018
    Eu market dashboard 62976km .....
  16. #13
    Jul 2019
    US
    Alba2, this dump works on my RIO. Except the fuel consumption is weird, I mean I see the km/l but the label is l/km.
