This is automatic programming when you switch ignition on
If you cant program the remote means that your remote is wrong
Try ASK 0523 PCF7941 or ASK 0536 PCF7961
both will start the car but with only one will work the remote
Any one got an idea how to programme 2007 Berlingo new remote fob tried every tricks no joy any one.
super jumbe (20th September, 2019)
This sort as the picture with seperate Chip T14 ID46
Berlingo Remote Head 02-08
Citroen Berlingo M59B Models
Genuine Part Number: 6554RH
Citroen Remote with T14 ID46 Transponder Chip.
PCF7936
I have encounter some off these, even with central locking installed.
In the bsi the remote function i not always activated.
Check it, using lexia,
super jumbe (21st September, 2019)
Sorry my mistake I thinked about new shape
Car is coming on Monday and I wonder this instruction is any good.
CITROEN Berlingo
(earlier models with remote key fob)
1. Separate the key fob from the standard key.
2. Insert the key into the ignition switch and turn it to position I (accessory position).
3. Hold the remote fob towards the receptor at the front of the vehicle.
4. Press the large button on the remote, followed by the small button.
5. Repeat the procedure for a second remote at this stage (if applicable).
6. Turn the ignition off.
7. After approximately five seconds, the remote(s) should function correctly.
for those i use kd PSA CIR48 Berlingo,programming with sbb,after chip programming it ask for remote adapt,everything works ok
Does it have to be SBB!
Lexia do that as well
You need to go in 206 mux on pp2000 and change
Envoyé de mon SM-G965F en utilisant Tapatalk
have the same with my work van , diagbox shows a remote key and have pincode but tried 3 keys and remote will not work ,
