Results 1 to 4 of 4
    marcolr's Avatar
    Default DAE Modus TRW 8200 433 517 DF002
    Could someone help me with repaired file to clear DF002? If itīs not possible repair my original file, I can use a virgin file and code with Clip.
    Thanks in advance
    If my post was helpful press Thanks button!!
    rafal's Avatar
    UK - PL
    test..............
    need help
    now my goal is to buy xp-005
    who will help?
  3. The Following User Says Thank You to rafal For This Useful Post:
    marcolr (26th September, 2019)
    marcolr's Avatar
    Quote Originally Posted by rafal View Post
    test..............
    The file doesn’t work. The DF048 is present in the UCH and the car doesn’t start. I tried to adapt the DAE with the Clip and the options are disabled in the software.
    marcolr's Avatar
    Solved!!
    I donīt know how it works but now itīs ok. I try differents virgin files but no ok for my part number. The car always starts and no errors but when I diag with Clip said me that ecu is not recognized.
    After lots of tries with many files, I tried again with rafal file and all was ok. Car starts, no more DF002 in DAE and no more DF048 in UCH.
    I donīt understand because the first time I tried with rafal file the car doesīn start and get DF048 in UCH and now with same file works.
    Thanks!!
  6. The Following User Says Thank You to marcolr For This Useful Post:
    rafal (26th September, 2019)
