Well, they may have been byte swapped from what your programmer reads and writes.
Are you writing them as 16 bit?
Post one of the dumps and the large number it displays.
Ok... Here is a dump showing 404000....
And will try swapping next...
And this one shows 4010 kms....
I can't make any sense out of any file or result you posted.
I think you need a different programmer. Or learn how to use it properly.
angelo44 (30th September, 2019), MileageAudit5 (25th July, 2020)
try this mate ..
angelo44 (28th September, 2019)
Reviving the thread.... After fixing the programmer issue, its confirmed - 19 Corolla has mileage in c66, and its Denso on line 0x010...
Now the 19 is diff than the earlier versions (on screen menu is driven by CAN/steering wheel buttons).... So I need a good 2019 dump in kms if anyone has to share....
JammerOne - your dump shows 17500 in Trip B.. most likely because its a 17?
BTW, I found a Corolla 19 dump on DK, but it shows in Miles... not sure if its the data or maybe its not for the model I have.....
I'd appreciate if anyone can share a file for a 2019 in kms... I dont care about kms...
Thanks everyone for all the help so far!!!
A
If you want...you can test this one:
jomberykaso - many thanks for the quick reply, but this 18 dump is same as a 17.......
Here;s a 19 dump in miles.... showing 17500 kms (10k+ miles).....
Your file is the same as this post but with other "mileage", however that file has not mileage, mileage is in Spansion mcu
https://www.digital-kaos.co.uk/forum...=1#post3641149
clusters I think he needed some kind of confirmation......
hi
c66 denos canbe done without open on cluster diag....
done one rav4 it dosenot has c66 like in the picture it show c66...that i did fujitsu points and need drive 5km and it become back to normal
RAV4 and Corolla has same board model (and same parts). However, RAV4 is in Fujitsu, and Corolla in the c66, just like the earlier years..
The example i posted above with a working dump was just.... an example... To show which dump works on this model vs a earlier model. Too bad it seems to be in miles.
Not sure why everyone thinks the Spansion S29GL128S has the mileage for Corolla.... when i change in c66, it changes on display... and in the car...
Has anyone modified the Spansion S26 and it worked too?
Has anyone corrected a 19 model with a Spansion mcu?
I am asking because maybe is in 2 locations.....
S29GL128S this flash which includes firmware and animation for the lcd screen. Not for storage mileage. Other locations maybe in abs or srs.
