2019 Toyota Corolla MB91F060BS
Page 1 of 3 123 LastLast
Results 1 to 15 of 34
    Feb 2011
    North of Bronx
    276
    Downloads
    Uploads
    Default 2019 Toyota Corolla MB91F060BS
    Hello DK!
    Can somebody help change 28689kms in 17500kms? This looks like a RAV4 Denso.
    Also, after change, do I need drive car to show new? Or will show on the bench rightaway?
    Thanks in advance!
    A
    Feb 2011
    North of Bronx
    276
    Downloads
    Uploads
    I read with smelecom multiplex. But it doesn't write back correctly... Anyone know if the BCM2 is better to write? After write, it still shows old mileage.
    Or maybe can help calculate dump above..
    Thanks,
    A
    Sep 2009
    2,250
    Downloads
    85
    Uploads
    looks like bad.......................................
  4. The Following User Says Thank You to nikz For This Useful Post:
    angelo44 (22nd September, 2019)
    Feb 2011
    North of Bronx
    276
    Downloads
    Uploads
    No, its not a bad read, Most likely its not in the FUjitsu. Maybe in the c66 like another poster said? What got me is that the unit is almost identical with the RAV4... same board #, same components... Spansion S29GL128S MCU... etc...
    Will try to read the c66...
    A
  6. #5
    Sep 2014
    17
    Downloads
    68
    Uploads
    Show pictures ecu and inside board
  7. #6
    Feb 2011
    North of Bronx
    276
    Downloads
    Uploads
    Here they are... very similar to the 18 RAV4...
  8. #7
    jomberykaso's Avatar
    Sep 2013
    Chillan - Chile
    2,071
    Downloads
    361
    Uploads
    maybe it's a c66
    Please use Thanks and Rep button if I solved your problem.
    for Fast File Service contact me by Whatsapp +A96C969E6E9 xored
  9. #8
    clusters's Avatar
    Mar 2015
    Canada
    1,096
    Downloads
    22
    Uploads
    The data is in eeprom and SPANSION processor, doing the eeprom only will not work.
    The Spansion algo is like a Fujitsu, but with a different constant to get the CS.
    https://www.digital-kaos.co.uk/forum...-Camry-Mileage
    Please DO NOT PM me asking for help.
    Post in the forum, that is what it is here for.
  10. The Following User Says Thank You to clusters For This Useful Post:
    Killer76 (23rd September, 2019)
  11. #9
    Sep 2014
    17
    Downloads
    68
    Uploads
    Quote Originally Posted by clusters View Post
    This not Camry. This Corolla with Fujitsu. Look at the picture.
  12. #10
    Sep 2014
    17
    Downloads
    68
    Uploads
    I think mileage in small c66 msop.
  13. #11
    Feb 2011
    North of Bronx
    276
    Downloads
    Uploads
    Most likely it is stored in the c66.... but I may not find out since the hot air gun decided to give it a lift into the abyss...... So now looking for a new unit.....
    To be continued........
  14. #12
    clusters's Avatar
    Mar 2015
    Canada
    1,096
    Downloads
    22
    Uploads
    "I think" "Most likely"
    If it has a Spansion processor it controls the display and stores the mileage. But go ahead and experiment.
    As I understand it from research, 2019 Corolla is the same setup as the 2018 Camry.
  15. #13
    Feb 2011
    North of Bronx
    276
    Downloads
    Uploads
    I just confirmed... it is stored in the c66. I tried replacing the lost eeprom and I get diff #s with diff dumps.
    Like I said above, this is very similar to a RAV4, not Camry... All parts are identical to 18-19 RAV4.
    Now if I can just figure out the algo...............
  16. #14
    clusters's Avatar
    Mar 2015
    Canada
    1,096
    Downloads
    22
    Uploads
    Post a file and it can be corrected.
    I guess what I read is wrong.
  17. #15
    Sep 2013
    Chillan - Chile
    2,071
    Downloads
    361
    Uploads
    Algorithm is Denso
