No one could help?
Is it possible to make virgin Jonson Ecu?
Or maybe to swap eeproms?
Hi friends. Need to swap ecu for this car. Have one VALEO and one Jonson Control. Take a look at picture..
Does this two are compatible? How to swap ?
Thank you in advance.
No one could help?
swap eeprom and u will see................
need help
now my goal is to buy xp-005
who will help?
jackie86 (23rd September, 2019)
Hi!
I'm not sure does these two are compatible cos I always use the same type of ecu when I have to swap.
Regularly the eep swap should be enough to swap the ecu but this is also the case when you use the same type of ecu.
Of course there are some compatible ecu's too but I never tried to play whit it.
Conclusion:
Your swap could work but you could have also some alian behavior of the engine and the most dangerous situation could be if you use the original eep ic ( desolder - solder ) the donor ecu could maybe kill the content of the original eep.
So, make a backup first of the eep and then put it to the donor ecu.
It is up to you, do you wish or not to spend a bit of your time to check and pls report the result.
I hope I helped a bit.
My best regards.
Sent from my SM-J500F using Tapatalk
Perfect!
I'm really happy cos you succeed the job and a good theory is put into practis.
My best regards.
