Anyone?how is possible to changing bytes into external flash after connecting ecu to car?
Hi all l have this car with faulty ecu atos prime 1.1g4hg engine.car had water inside after a rain.ecu was blown.i found similar ecu 39110-02800 the original was 39110-02BA5.with ktag read the original all data external micro eeprom and write in the used one.car started fine but after while switched off and no starts any more.i removed ecu read it again and i found in external flash some bytes that was changed.i write again the previous original flash but when i plugged it same thing happens.can you help with this?attach all files original used and the last modified read.
Do the same job with ktag.
Verstuurd vanaf mijn SM-G960F met Tapatalk
Sedat Garip
Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
Diesel + petrol All cars
Manual Adblue dpf egr Opf tested working solutions
Belgium
With Kind Regards,
Don't forget hit thank button if i helped.
