Test and report
We lost the car keys in the woods (no spare keys).
The car is old. We used the key from another Toyota ( old lock , car kranck but not start).
Can someone make immo off?
Toyota Hilux D4D 2004. 2.5 Diesel. 75kW.
ECU is Denso 89666-35280.
On the board 175822-600*.
EEPROM is 93C56.
Test and report
jozoku1 (21st September, 2019)
I also have a 2013 hilux looking for immo off file can you help me.thanks in advance
Thanks m8.
First, I disconnected the immo, then connected the ECU.
Car won't start.
BR.
you can try to sync immo te ecu, simple procedure just jampiar 4 and 13 from obd2 socket for 30 minutes
[QUOTE = Sandmanrr; 3676797] Eu também tenho um hilux 2013 procurando um arquivo immo off, você pode me ajudar. Obrigado antecipadamente [/ QUOTE]
93c66?
In ECU _93c56 _ 100%
We lost the key with a transponder. Key from the other (older) toyota can turn the ignition on and crank with shaking the key (old lock ). The car is mostly driven offroad through the forest.
test and report
Sistema de chaves G?Sandmanrr
