Page 1 of 2 12 LastLast
Results 1 to 15 of 27
    Feb 2019
    Post BMW 123d Remap+Mappack
    Hello everyone, I'm the owner of a BMW E82 123d, who first came here to learn a few things mostly out of curiosity. However, I got caught in this world of ECU remaping, and so after months of search, calculations and taking serious risks with my beloved car, I managed to create a very complete map pack for my car's ECU and a stage 1 remap. But I could have never done it without the help of people that shared their valuable information, purely out of good will, and helped me throughout this journey.
    As I see things, now is the time for me to do my part and share what I learned, so here it goes.
    What I have for you today is:
    1. My original internal flash file
    2. My remaped internal flash file
    3. My custom mappack, which includes:
    • Torque monitoring maps
    • Torque limiter maps
    • Boost maps
    • Start of injection maps
    • Duration map
    • Rail pressure maps
    • Nm to I.Q. maps
    • Lambda maps (smoke limiter maps)
    • EGR hysteresis maps
    • DPF switch
    • Gear and differencial ratios.
    The ECU is, of course, an EDC17CP02, but you can use the files with the mappack to guide yourself if you have an EDC17C06, they are extremely similar.
    If you're wondering about my setup, here it is:
    • WinOLS 2.24 (cracked version)
    • Galleto FGTech v54 0475 (bougth from AliExpress)
    • Windows 7 - 64 bit PC (to use with Galletto)
    Reading can be done via OBD, you'll only get a partial read but it's the part that contains the maps. For a full read or writing, it must be done in Tricore boot mode, with the ECU opened.
    I don't mind if you copy this remap to your car, I don't even care if you make any money out of this, but if you value my work at least press Thanks and Reputation.
  2. The Following 56 Users Say Thank You to toblast For This Useful Post:
    adyzamfir (7th January, 2022), alcorte (15th November, 2019), Amad375 (30th May, 2021), amrilyes (6th October, 2019), angeloleon98 (11th February, 2021), Antastra1989 (30th March, 2020), Arke (26th January, 2023), ay06634 (5th August, 2020), betawgazie (6th March, 2023), BmwMerc (15th September, 2023), Boolbi1 (15th November, 2019), centrozax1 (28th January, 2020), chunkyy (15th September, 2023), CptnKvin (10th May, 2021), devil85 (14th October, 2023), ditmplx (14th October, 2019), dmx888 (3rd January, 2020), Emil98 (12th February, 2021), gabrielyguana (4th April, 2020), geedot187 (19th September, 2020), gregwon (31st January, 2021), Gutel (5th November, 2023), hbalazs (15th November, 2019), immo786 (30th October, 2019), ivchoto1 (20th May, 2022), jointone (31st December, 2021), lsalt100 (11th October, 2023), madjqker (2nd April, 2023), Majster007 (18th October, 2020), mancioks (31st October, 2019), marcio205 (30th October, 2019), metock (1st August, 2022), moky (15th November, 2019), naskochipa (15th November, 2019), nikolovphilip (31st December, 2020), OMAR835 (16th December, 2019), osys (12th November, 2023), paulo23pacheco (30th September, 2019), progamer1233 (25th September, 2019), RBTuning (15th November, 2019), seanyc (28th October, 2022), sniegavirs (30th October, 2019), Stuie1982 (11th November, 2021), supernaturel13 (3rd April, 2024), Swattie1 (8th July, 2022), tazman112 (22nd May, 2023), therape (8th July, 2021), victorr13 (21st August, 2023)
  3. #2
    Oct 2019
    Portugal
    i cant download the file m8
    NASTASE's Avatar
    Feb 2010
    ROMANIA
    Your Smoke limiter maps are in reality Lambda maps.
    Real engines don't need forced induction
    Who needs a turbo when you have a stupidly quick naturally aspirated engine?
    Feb 2019
    Quote Originally Posted by marcio205 View Post
    The link is good, I just tested it...
    Quote Originally Posted by NASTASE View Post
    I know they are, I chose to call them "Smoke limiter maps" because I thought it would be easier to understand what they do. I'll edit the original post to make it technically correct.
  6. The Following 2 Users Say Thank You to toblast For This Useful Post:
    Boolbi1 (15th November, 2019), CptnKvin (13th May, 2021)
  7. #5
    Nov 2019
    Hi toblast, I appreciate your remap edc17cp02, I indeed looked at my ECM titanum, really perfect! I have an edc17cp45 X6 E71 30d xdrive (245 hp _ 540 Nm) but no driver on my ECM damage for me I can not remap. is it possible to reach off 320 hp and 660 Nm? Can I send you my original file please? sorry for my words i'm french. Regards Boolbi1KTAG - BMW X6 30d E71 _ 04-2013.jpg
  8. #6
    Nov 2019
    Hello toblast thank you for your reply, how can i send to you the file i tried like the picture sent yesterday but it's impossible for file do you have a solution please ? If you want with my email skyliner2009@live.fr i think that's possible to download the file (only 4 mb).
    Regards
  9. #7
    Feb 2019
    Hello Boolbi1, sorry for the late reply.
    I can't help you outside the realm of EDC17CP02 and EDC17C06. I've only worked with diesel E8x cars, which means only N47 engines, which means those are the only ECU's I've worked with.
  10. The Following User Says Thank You to toblast For This Useful Post:
  11. #8
    Nov 2016
    Nice work!
  12. #9
    tunelab's Avatar
    Feb 2019
    about mappack is good but remap file can say not good not bad
    this file can be much stronger than what is tuned and the most important is to know how an engine system work
    only calculation is not enough need to know where and how to apply it
  13. #10
    Jan 2020
    can you help me with a power increase for my bmw x3 please ?
    same ecu, edc17cp02.
    HW:08506373
    SW: 1037399768
    It's an automatic transmission, 2.0d, n47 177hp, 2010.
    Thnaks in advance.
  14. #11
    Feb 2019
    Quote Originally Posted by dionhpt View Post
    Nice work!
    Thanks!
    Quote Originally Posted by tunelab View Post
    Thanks for the feedback. I also think there's room for improvement, I was thinking about increasing rail pressure and touch the smoke/lambda maps if need be. If you don't mind, please share what you would change.
    Quote Originally Posted by vDiv View Post
    HW:08506373
    SW: 1037399768
    Thnaks in advance.
    Sorry, but I won't spend time making a remap for free. The mappack with the remap file should be more than enough for you to be able to make a decent file for that car. If you need help, that's ok, but I won't make you a file.
  15. The Following User Says Thank You to toblast For This Useful Post:
  16. #12
    alonedark's Avatar
    Feb 2017
    good.jpgthis is good????
  17. #13
    Feb 2019
    What is good? I can't see shit on the image, and I don't even know what it's about...
  18. The Following User Says Thank You to toblast For This Useful Post:
  19. #14
    Gracias, lo usare de ejemplo para mi 520d-
  20. #15
    Junior Member AperoMyke's Avatar
    Sep 2020
    France
    Thank you for your precious contribution
