Results 1 to 2 of 2
    Exclamation 2004 S60 T5 AWD AUTO - Repair Help please!
    History
    ALL KEYS LOST + new key ordered from the dealer!
    CEM NUMBER 08688513
    Locksmith butchered the original CEM (DAMAGED IT TOTALLY Starts smoking then burns dudses. He also buggered up the 28F400 memory)
    I purchased a used CEM from a XC90 with the same part number
    I desolder and read the old CEM memory.
    I can read and write capability of the 28F400 without issue using BDM method.
    I have volvo syncro which will allow my to sync the ENGINE ecu 5P08 with the CEM
    I have found a few CEM dumps here from similar vehicles.
    Any advise on what BIN to write to the CEM, adapt the NEW key
    I understand I need to get the PINCODE from the CEM dump to program a key?
    Attached
    BIN from damaged cem (DAMAGED-AB28F4400BX.bin)
    BIN from car found here DK (2004-s60Flesh TB28F400B5B)
    BIN from supposed to be new CEM found here DK (new bcm volvo s60 synch.bin)
    I also have VIDA. Thanks
    Your help is much appreciated.
    Last edited by learing1; 25th September, 2019 at 12:52 AM. Reason: files did not attach on first attemp
    firestator's Avatar
    Oct 2010
    MINSK
    Quote Originally Posted by learing1 View Post
    History
    CEM NUMBER 08688513
    Attached
    I can solve your problem, in skype
  3. The Following User Says Thank You to firestator For This Useful Post:
    learing1 (25th September, 2019)
