Results 1 to 7 of 7
    Nov 2015
    Default A3 8P PDC EEPROM ERROR 8P0919475E
    HI
    can U guys help me fix this problem
    8P0919475B/8P0919475E
    May 2017
    dtc is????
    Nov 2015
    16347 - Control module - eeprom error
    May 2017
    you got problem with coding, chks, eeprom or unit defect... dtc deletes didnt fixed hardware issues...
    Nov 2015
    the problem is due to a weak battery
    Its standard problem on that pdc (8p0919475f, and passat b6 etc) IT can be fixed
    robert1232's Avatar
    Dec 2010
    Ireland ;)
    need fix Eeprom
    8P0919475E
    FLASH 4L9IN
    8park sensor
    orginal is FF
    PRESS THANKS AND REPUTATIONS (STAR) BUTTON
    I don't give others the password to the file. I'll send my file and I'll try to make it
    robert1232's Avatar
    Dec 2010
    Ireland ;)
    no help frends??
