Results 1 to 2 of 2
    Aug 2018
    Default Just a few questions
    I just have a few questions about flashing ECU's, im doing this now for one year and im using tools like ktag.
    1. Before I remove an ECU from the car I always disconnect GND from the batterie but is this really necessary? I think it should be enough if I just remove the key and wait a few minutes and then unplug the ECU.
    What do you guys think?
    2. While flashing an ECU how do you set up your power supply? I set my power supply to 12,9v and 5A. I know that some ECU's need more than 1A or 2A. What settings are you using ? Is 12,9v and 5A enough for flashing?
    Thank you for ur help!
    Jan 2017
    USA ����
    1. Thats laziness talking
    2. No thats not right at all
    You want a maintainer
    You set its voltage and it keeps it precisely there without fluctuation regardless of how many amps it is pulling
    Maintaining the voltage precisely hence its name
