Hi.
Please generate NEC key from EIS file.
EIS: 209 545 09 08
AKL
File for NEC programmer.
Thanx!
Hi.
EIS: 209 545 09 08
AKL
Thanx!
king alie (5th January, 2020)
There ya go.
<---- Coin of the Realm.
castin (15th October, 2019)
Hello.
I have a request, could anyone check the EIS file or is it not damaged? Im create key, IR analyzer show status "first time", key number - all OK.
After first plug key, LED on key turned on and then turned off. Key status "active". Unfortunately, the key won't turn on.
Im check other EIS with working KEY and ESL emulator - all OK, key turn on.
Im chcek coil EIS, relay coil, IR mirror cleaned.
Eis file looks good. Maybe problem with key.
Key looks good. Key analyzer read it ok, key send IR sięgnął.
check the nec is soldered good. try to heat motorolla (maybe ezs problem).
NEC is ok, key ok. Im heat Motorola - no effect.
Please somebady check this flash from proc. Meybee is corrupted.
I don't know the previous history of the car.
Thanx
PS. New KEY prepare by NEC programmer see in IR Analyzer like "First Use"
After try turn (but can't) key hawe status "Active", key count go up.
After read eeprom from EIS, dump tool see new position of key.
Ignition relay, 12v, 5v - OK.
I dont see clearly your NEC programmer ,if there is gold NEC programmer you will need to convert key file to your programmer . The converter is included on your software.
Pepi im use china Benz Nec programmer (gold). Work OK, two times program NEC and key work fine in EIS. This converter is for convert BIN NEC file to IR Programmer file (i think). Normaly, im load generated NEC file and key work OK.
Im try add key to my second EIS (the same PCB, part number, motorola 1L85D) with working key (big with motorola.051). Im generate KEY via dump tool, but key won't turn - red led stay ON. Meybee wrong type key im use, wrong NEC chip?
Hawe two: 567897081 and 567897061.
Hmm, next day and test:
I don't know why, but this EIS only works with a large key on Motorola.
Maybe someone will generate files for keys on nec again?
I have a 7061, 7071, 7081 ending - is that a difference?
Like on photo: 233.186.051A
14/99
Yes, i hawe other the same EIS and not work nec Keys. Im use esl emu and big key work ok. Strange...
I'm going crazy with this ignition. Unfortunately, the key on the NEC still doesn't work.
The NEC already screams "don't cook me anymore".
A friend will program NEC on another programmer and then rule out a programmer error.
I may be making a mistake somewhere, but everything seems to be OK.
