Page 1 of 2 12 LastLast
Results 1 to 15 of 21
    castin's Avatar
    Oct 2015
    Poland
    Default Mercedes CLK 2003 key from EIS
    Hi.
    Please generate NEC key from EIS file.
    EIS: 209 545 09 08
    AKL
    File for NEC programmer.
    Thanx!
  2. The Following User Says Thank You to castin For This Useful Post:
    king alie (5th January, 2020)
  3. #2
    droidwayne65's Avatar
    Aug 2015
    North America
    There ya go.
    <---- Coin of the Realm.
  4. The Following User Says Thank You to droidwayne65 For This Useful Post:
    castin (15th October, 2019)
  5. #3
    castin's Avatar
    Oct 2015
    Poland
    Hello.
    I have a request, could anyone check the EIS file or is it not damaged? Im create key, IR analyzer show status "first time", key number - all OK.
    After first plug key, LED on key turned on and then turned off. Key status "active". Unfortunately, the key won't turn on.
    Im check other EIS with working KEY and ESL emulator - all OK, key turn on.
    Im chcek coil EIS, relay coil, IR mirror cleaned.
  6. #4
    Sep 2015
    DK
    Eis file looks good. Maybe problem with key.
  7. #5
    castin's Avatar
    Oct 2015
    Poland
    Key looks good. Key analyzer read it ok, key send IR sięgnął.
  8. #6
    Sep 2015
    DK
    check the nec is soldered good. try to heat motorolla (maybe ezs problem).
  9. #7
    castin's Avatar
    Oct 2015
    Poland
    NEC is ok, key ok. Im heat Motorola - no effect.
    Please somebady check this flash from proc. Meybee is corrupted.
    I don't know the previous history of the car.
    Thanx
    PS. New KEY prepare by NEC programmer see in IR Analyzer like "First Use"
    After try turn (but can't) key hawe status "Active", key count go up.
    After read eeprom from EIS, dump tool see new position of key.
    Ignition relay, 12v, 5v - OK.
  10. #8
    pepi's Avatar
    Jan 2010
    I dont see clearly your NEC programmer ,if there is gold NEC programmer you will need to convert key file to your programmer . The converter is included on your software.
  11. #9
    castin's Avatar
    Oct 2015
    Poland
    Pepi im use china Benz Nec programmer (gold). Work OK, two times program NEC and key work fine in EIS. This converter is for convert BIN NEC file to IR Programmer file (i think). Normaly, im load generated NEC file and key work OK.
    Im try add key to my second EIS (the same PCB, part number, motorola 1L85D) with working key (big with motorola.051). Im generate KEY via dump tool, but key won't turn - red led stay ON. Meybee wrong type key im use, wrong NEC chip?
    Hawe two: 567897081 and 567897061.
    Hmm, next day and test:
    I don't know why, but this EIS only works with a large key on Motorola.
    Maybe someone will generate files for keys on nec again?
    I have a 7061, 7071, 7081 ending - is that a difference?
  12. #10
    Aug 2015
    North America
    Quote Originally Posted by castin View Post
    What's the part number on the Motorola key?
  13. #11
    castin's Avatar
    Oct 2015
    Poland
    Like on photo: 233.186.051A
    14/99
  14. #12
    Aug 2015
    North America
    14/99
    Ahhh, didn't see that you'd posted the numbers. I think they all use 051 format but that doesn't explain why the NEC keys don't work work, while the Motorola does. Testing with an unlocked esl or emu?
  15. #13
    castin's Avatar
    Oct 2015
    Poland
    Yes, i hawe other the same EIS and not work nec Keys. Im use esl emu and big key work ok. Strange...
  16. #14
    Aug 2015
    North America
    Try this combo. Pick a key, any key.
  17. #15
    castin's Avatar
    Oct 2015
    Poland
    I'm going crazy with this ignition. Unfortunately, the key on the NEC still doesn't work.
    The NEC already screams "don't cook me anymore" .
    A friend will program NEC on another programmer and then rule out a programmer error.
    I may be making a mistake somewhere, but everything seems to be OK.
