Results 1 to 12 of 12
    Jan 2017
    Default PLEASE DPF OFF THIS FILE
    hi friends need dpf off this file switch solution dont work like in first edc16c39 ecus,thanks in advance
    its a giulietta jtd 140hp edc16c39
    Oct 2018
    Bejaia
    it's ...... dpf off
    Jan 2017
    [QUOTE = ridha still; 3681896] es ...... dpf apagado [/ QUOTE]
    its the same file friend...
    any good solution?
    Jan 2017
    Nobody? Please help
    pike's Avatar
    Sep 2013
    Exclamation
    not exist DPF off switch for EDC16C39 Euro5, send original file.
  6. The Following User Says Thank You to pike For This Useful Post:
    kinketotua (30th September, 2019)
    Jan 2017
    [QUOTE = pike; 3682223] Hola,
    no existe el interruptor de apagado DPF para EDC16C39 Euro5, envíe el archivo original. [/ QUOTE]
    here its the ori
    Jan 2017
    Nobody,please help
    Member xam4's Avatar
    Jun 2016
    Earth
    Try this solution:
  10. #9
    pike's Avatar
    Sep 2013
    Arrow Alfa Giulietta dpf off
    it will not work
  11. The Following User Says Thank You to pike For This Useful Post:
  12. #10
    Jan 2017
    Ok,have you got a good solution?
  13. #11
    Summa's Avatar
    Nov 2018
    There are always good & tested solutions.
  14. #12
    Jan 2017
    [CITA = Summa; 3683585] Siempre hay soluciones buenas y probadas. [/ CITA]
    sure,otherwise is how know to do it
