Update it to a 3bar.
Cheers
Robin B
Kess V2 . K-Tag
MiniPro . UPA . VVDI2
hi guys need help with my 1.8tfsi 2009 manual audi a3
I have been having trouble with my MAP sensor the car requests boost but the MAP sensor actual is stuck at 10. I have tried 2 other new sensors original and have checked wiring.
Error code is get is: P0237 - Turbocharger boost sensor A Low input. It changed to high input if i unplug the map sensor.
Can someone delete the pCODE P0237 from my file please. Also if possible to delete the MAP sensor completely off the ECU please
Will be a great great help
Cheers
Robin B
Kess V2 . K-Tag
alextinou (28th September, 2019)
All fuses checked and also original map has been put on it. Still the same
Could you help me delete pcode or take it off the map file please
Hi Robin. That won't help. There's a fault somewhere need the pcode mapped off and the map sensor off the ECU file
put again the oem sensor. the difference 3 bar and oem is only in eyes.... ...dont realy need 3 bar.
for 3 bar sensor need remap it.
most likely broken wires near sensor...(maybe and on the engine loom).
Also check for boost leaks..
