Hi. out solder 5p08, then read galletto obd.
sagie1zn (28th September, 2019)
do you have pinout to do this on the bench
are you saying that i must desolder 5p08 and then plug back in vehicle and read and write. Also do you have pinout for doing this on bench
take a look at this....
sagie1zn (29th September, 2019)
connection on bench same as in picture. take out 5p08 or make it virgin and read with galleto by OBD or on bench. GL
i use same connection and still no luck. i select CAR, PEUGEOT, BOXER, EDC15C2 and result : error send wake. Data reading error
i also connect power supply, also eeprom chip is desoldered, still same result
i am not sure sir. i dont do ecu normally but this is a project for me personally. You seem to be 100% correct because as soon as i change to edc15c7, it read ecu data. when start reading file it say: error SK2 , error seed key.
solder back eeprom, and connect boot pin...
sorry, under TOOL BOOT, which type to choose under CARS and SELECT DRIVER. thanks for the assist
hi, it eventually started to read but im maybe missing something. i put the ori read file in hex editor and compared to immo off file and cannot see the difference. normally hex editor will say NO DIFFERENCES FOUND, but it does not in this case. So there is obviously a difference but due to old age, i cannot see where
Hi. both files are immo off partial
what does this mean "partial". so what will happen if i write any of these files. History was that the original file "boxer" did start the car but switched off after a few minutes, maybe less than a minute. So i found another file to write, will i have a problem with this also
