Results 1 to 3 of 3
Hybrid View
    Mar 2018
    Default key cut code Citroen
    I have 2 used Citroen cars (Xsara Picasso 1.6 petrol of 2009 and C3 1.4 petrol 1st series of 2009) and in none of the 2 I was given the code to cut the key. is it possible to trace the code via VIN? Or in some other way?
    Dec 2010
    Nottingham
    you have a number of options open to you ;
    1) pay an auto locksmith to decode these locks for you
    2) buy the key codes from a code broker , dealer or supplier from the vin number
    3) buy and learn to use the relevent lishi 2in1 pick and decoders ;
    a) the C3 2009 will be the VA2T pick and decoder , all cuts are in the door , so pick and decode
    b) the xsara picasso will be the sx9 pick and decoder , but as this model is likely to have the side cuts the tool will only pick and decode the ignition , you can then strip the door lock down to read the side cut values .
    4) remove and strip down the locks to decode
    5) if the car already has a key then trace the blade or site read the key by eye
    castin's Avatar
    Oct 2015
    Quote Originally Posted by rapidlocksmiths View Post
    Best option 4.
