Results 1 to 2 of 2
Hybrid View
    Default Trying to read 1K79X - but can’t connect
    Removed this mcu from pcb, trying to read the mc9s12dG256 mask 1K79x, trying to read the flash but it is not connecting to the chip,
    am using R270+ programmer, xprog also can’t read it...
    all pins are soldered well... I have realized that when I bring 2 pins , I am able to read the eeprom but the flash won’t be able to verify out, even though it may read alright but during the the verification process it give error..
    i need help
    keturi's Avatar
    Oct 2010
    Lievatu
    Wrong connection. Xprog-M manual shows ONLY H256 23 pin should be free and oscillator should be connected with 12-14 cm twisted pair.
  3. The Following User Says Thank You to keturi For This Useful Post:
    forumoto (5th October, 2019)
