Page 2 of 2 FirstFirst 12
Results 16 to 23 of 23
Thread: A tricky riddle
  1. #16
    V.I.P. VIC
    Mjolinor's Avatar
    Jan 2009
    Burnley Vicshire
    I think given the location of the donkey one has to assume that it is Zazuum (Owned by Raseem) and he has the power to form a miniature tornado that can destroy anything in its path.
    Maybe he uses his "don key" to get out?
  2. #17
    Sep 2020
    USA
    What if the walls are not high and the donkey will just cross?
  3. #18
    Jan 2018
    even we give the right answer , you will say its the same what the donkey thinks,,hhhh
  4. #19
    darrenhyland's Avatar
    Aug 2010
    IRELAND
    Buzzard's will lift it out piece by piece
  5. The Following User Says Thank You to darrenhyland For This Useful Post:
    Meat-Head (27th December, 2020)
  6. #20
    Aug 2020
    Quote Originally Posted by DeLuXe View Post
    Hi!
    I got a tricky riddle. Please this is a not only a tricky question but you as a replier should not be offended because this is also a joke.
    So lets begin the guessing..
    There was a big donkey in the middle of the desert.
    This donkey is trapped within 4 walls
    This walls are of concrete and without any doors, windows or roof.
    How will this donkey get outside of the 4 walls ?
    Enjoy.
    Best regards
    Well the answer is obvious isnt it, ONLY you knew,
    " There was a big donkey in the middle of the desert.
    Do tell us how you got out mate?
    HaynesPro online 2024 + AC 2022.02a available, message for where to get them!
  7. The Following User Says Thank You to crouchinggerbil For This Useful Post:
    Meat-Head (13th September, 2021)
  8. #21
    Aug 2010
    IRELAND
    A wall can be a single row of blocks or twenty feet high. No specific height was given therefore logic dictates the wall wasn't high enough to keep the donkey in.
    Tools owned..... Kess3 Master, Bitbox, TGFlash, VVDI2 Full, VVDI Prog, VVDI MB Tool, VVDI Mini Tool, VVDI Key Tool Max Pro, VCX series for BMW Ford Mazda Jaguar Land rover VAG Toyota Volvo GM, PCM Flash + Scanmatik2, Lonsdor K518ise, Magic tank and every other piece of Chinese crap out there.
  9. The Following User Says Thank You to darrenhyland For This Useful Post:
    Meat-Head (15th February, 2022)
  10. #22
    Aug 2010
    IRELAND
    Or he was freed after the local tribe couldn't get an ounce of sleep due to its wailing all night.
  11. The Following User Says Thank You to darrenhyland For This Useful Post:
  12. #23
    PocketHero's Avatar
    Jun 2017
    Budapest, Hungary
    Easy. The donkey gets angry, and kicks a hole out of Da wall, then walks out to the desert, and dies, because nobody told anything about water...
    Tapatalkkal küldve az én Power Armor 13 eszközömről
