Results 1 to 10 of 10
    Dec 2018
    Default Citroen Xsara Immo problem
    Hello guys, I have problem with Citroen Xsara 2001 - The car has keys, but doesn't start. I have tried to read the PIN Code from the BSI but couldn't so I decided to remove the IMMO from the ECU. I have killed the IMMO with IMMOKILLER (program) but the car doesn't start.
    Can someone tell me If i have removed the IMMO correctly or give me the PIN Code from the ECU dump file. THANKS
    ECU - BOSCH EDC 15 - 5P08C3
    The first file is the original file
    The second file is the removed IMMO file
    THANKSS !!!!
    Feb 2017
    Tunisia
    why are you doing the job upside down send the bci dump and we will give code and program your keys for your case as i know you can't make immo off you can just make you ecu virgin and in this case you will need to reprogram your keys in the two case you will need pin code send the bcm
    Dec 2018
    Mate, i couldn't read the bsi, because it is NEC that i don't have programmer for it. Can you give me the PIN from ECU? THANKS
    Feb 2017
    Tunisia
    i tried whiaout succes try this file immo off and reply password in pm check your box
    Dec 2018
    i haven't recived a message for the password. please send again. thanks
    Feb 2017
    Tunisia
    withaout pass
    Dec 2018
    Doesn't work...
    Sep 2013
    Quote Originally Posted by tyancool1995 View Post
    Doesn't work...
    Try make it immo off with fvdi last time work for me
    Dec 2018
    Fvdi? Is that a programme
    Dec 2018
    If I post a dump from the flash will it be easier for the PIN code?
