Results 1 to 3 of 3
    May 2018
    Lvov
    Default Mazda 323 f pin 93c56
    Hello. the car stopped running, errors P1621 P1624 The wire is propoim from immo to PCM I want to try to write the key, but the code is needed. Dump with PCM strange code FF FF FF FF, code will be 11111111?
    Hello.the car stopped running, errors P1621 P1624The wire is propoim from immo to PCM I want to try to write the key, but the code is needed. Dump with PCM strange code FF FF FF FF, code will be 11111111?
  2. The Following User Says Thank You to biggggi For This Useful Post:
    dpflaunch (6th November, 2019)
  3. #2
    Nov 2019
    Default MAZDA INMO OK
    SALUDOS TENGO UN ARCHIVO PARA USTEDES PERO NO SÉ CÓMO ENVIARLE UN CASO AUNQUE NECESITE DEJARME SABER Y TRATAR DE AYUDARLE.
  4. The Following User Says Thank You to dpflaunch For This Useful Post:
    biggggi (21st January, 2020)
  5. #3
    Quote Originally Posted by biggggi View Post
    Hello Mate,
    In your dump only PIN CODE is missing.However you can retrieve this PIN CODE by reading IMMO BOX dump that i foreseen to be the MITSUBISHI TYPE fitted with the 44 Pins Motorola MCU.
    Best Regards
  6. The Following User Says Thank You to ngakson2002 For This Useful Post:
