Results 1 to 5 of 5
    mr G's Avatar
    Sep 2019
    Default BMW 640d 2012 replace ECU
    Hello everybody,
    I have BMW 640d 2012. ECU was flooded with diesel and some diesel went in to ECU. Previous garage removed ECU and opened to clean it. Also they lifted the board and probably damaged processor. Now there is no communication with ECU (before lifting the board communication was ok). Then guy bring me damaged ECU, but I can`t read even in boot mode (totally bricked).
    Get second hand ECU, I checked, but it was opened before aswell, just this one have communication. I read all data in boot mode just in case. Now problem is ISN. Question is what options are to read/write ISN to ECU? BMW explorer and Autohex are out of my budget.
    Regards
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Quote Originally Posted by mr G View Post
    Hello everybody,
    Regards
    read cas unit and key...
    post it in forum...
    to get ISN...
    read new ecu....
    post dump in forum...
    let the ISN change in new ECU...
    When I help you press Thanks and Reputation...
  3. The Following User Says Thank You to figani For This Useful Post:
    mr G (5th October, 2019)
    mr G's Avatar
    Sep 2019
    what info from key is needed. i can see just ID
    mr G's Avatar
    Sep 2019
    key info
    cas4 data
    replacement ECU data
    all data attached.
  6. #5
    figani's Avatar
    Feb 2018
    key info
    cas4 data
    all data attached.
    better post all in the immo section...
    the mates there have more knowledge...
  7. The Following User Says Thank You to figani For This Useful Post:
    mr G (6th October, 2019)
