Results 1 to 7 of 7
    p1et's Avatar
    Oct 2013
    Default Kia Sorento 2003 remote programming
    http://lowratelocksmith.weebly.com/b...g-instructions
    I'm trying to program remote for this car using this methid but remote won't program in. When I connect jumper cable as per instructions and turn ignition ON, I see hazard lights on dashboard flash and stay solid. After pressing lock or unlock button for 3 seconds nothing happen (dash should go black) Remote 315 MHz in good condition but car don't have any working remote so I don't know, maybe car problem. But maybe someone tried this procedure and confirm this actually should work?
    Oct 2015
    same year europe model i did with t300. jumping wire with + didn;t work
    6841707059 576F526B 57416E5453 596F55 526F6B69424152
  3. The Following User Says Thank You to rokibar For This Useful Post:
    p1et (5th October, 2019)
    p1et's Avatar
    Oct 2013
    Thx I will try and report when customer return.
    p1et's Avatar
    Oct 2013
    Well I don't have T300 but I tried with Lonsdor and MVP and also failed.
    Also instruction from advanced diagnostics to bridge pin 5 and 17 in OBD 20 pin, turn IGN on and press lock 2 times didn't work
    qwertyuiop12's Avatar
    May 2013
    You remote wrong,try remote 433MHz
    ! ! ! I see hazard lights on dashboard flash and stay solid ! ! !
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by qwertyuiop12 View Post
    You sure? I think this remote is only 315Mhz. And this car have speedometer in miles per hour so american market which use 315MHz.
    May 2013
    If you see hazard lights on dashboard flash and stay solid,this means that you entered the remote control programming mode, now you need good remote,if 315 not work,try 433Mhz,or try other remote 315MHz,if all not work this means a problem with the unit itself in the car.
  9. The Following User Says Thank You to qwertyuiop12 For This Useful Post:
