Kess will if clone is stable & good quality also have battery support on the vehicle and I had hazard lights and seat belt engaged to reduce car going to sleep
bokilee (5th October, 2019)
This version needs to be patched first in bootloader with Original tools before you can read and write in OBD
AUTOTUNER, FLEX ,X17, TRASDATA / NEW GENUIS AND ALIENTECH MASTER OWNER.
FULL SWIFTEC AND EVC RESELLER
FILE SERVICE FROM 8AM - 9PM 7/7
BAPRO 4WD DYNO
BAPRO 4WD DYNO
figani (7th October, 2019)
bokilee (5th November, 2019)
Hi, I'm waiting KESS to arrive. I will post ID from KESS when arrived.
Best regards,
bokilee
Hi, kess arrived. I read it without problem about 1 hour and 30 minutes, and for writing also same time. I did not open the ECU and I did not pach ECU.
Thanks,
bokilee
jevgensolo (23rd June, 2021)
What kess did you use to do this? I have this ecu in my new car and i was goint to test the Bitbox/tatrix openport 2.0 solution via obd on this car.
Hi, this is the kess that I used with Ksuite253:
Same as i have then, got the red pcb one. But i did this ecu with Bitbox FID214 with china Tactrix Openport2 today without problems via OBD. Waiting on the original Tactrix Openport 2.0 as it costs near nothing new.
bokilee (23rd December, 2023)
