Results 1 to 7 of 7
    world
    Default w211 ZGW Assyst Plus, Oil Change odometer reset
    Is it possible to reset Assyst Plus and Oil Change data to 0km ? I try to edit the data but some of line cannot change it with carprog.
    Eeprom attached (readed with carprog)
    world
    solved..
    with star diag...
    brend's Avatar
    Oct 2015
    Same where
    Full repare away?
    world
    i just reprogram it and click reset all end of program. Everything was resetted to 0km 0 days
    dump attached after programming and reset;
  5. The Following 2 Users Say Thank You to gsmflasch For This Useful Post:
    auto80 (13th February, 2025), jomberykaso (8th October, 2019)
    Dec 2012
    I've reset everything to zero with me now, the question arises how you can enter all the data? Do you have to use special tools or does it work with Star Diagnosis?
    With which version of CarProg is it possible via the OBD2 connector?
    world
    Carprog connect the unit on bench, check the car prog manuel.
    Star can reset and erease everything when you an update.
    lechus111's Avatar
    Jan 2014
    Hi. Friend, can I ask you for the password to the archive?
    thank you
