Results 1 to 1 of 1
    Jan 2015
    Default AUDI A4 2008 year BCM2 problem
    hey guys audi 4 2008 battery crashes and after replacing the battery in bcm2 it has an error 16366 control module-internal malfunkcion .cpu 2 defective, faulty parking brake, on the board a flashing key yellow.
    the car fires but after a few ignition locks the key in the lock, remove the battery terminal and return and then it is ok.
    i have flash from bcm 2. can anyone help.thank you
    8K0 907 064 A BCM2
