Hi , I have a Vauxhall Vectra 1.8i Tourer 98 and i was wondering if anybody knew what type of ECU socket it has in it and which OP-COM unit will work with it....
Acestu
Acestu
If my post Helps, then Please Click the THANKS Button ,as i will do for you.
The Acestu Corporation.... More Powerfull Than You Could Possibly Imagine !!.........
Hi it has a 16 pin EOBD connector, located beneath the handbrake lever, under removable cover, so any Op-Com version should be OK.
HTH
Semper in Excreta
some times the cover is so tight it makes a used car sales man called dave look genorouis, think it lifts from the 'top'
Thanks Fellas, take it i can get one of these off ebay , with a connector that will connect to it ? , i want to connect it to my laptop and try and get some realtime info off it such as fuel mixture or voltage from lamda sensor...
thanks again
Acestu
