Results 1 to 7 of 7
    Germany
    Default Mercedes Sprinter W906 318CDI EDC16CP31 DPF off help please
    i have an Sprinter 318CDI 3.0CDI 184hp Model 2007
    and I need DPF off and i need DTC off for the error 3050" Lambda sensor upstream" .
    The file is readed with Kess and the ecu is an BOSCH EDC16CP31
    thank you for the help and Kind regards.
    takiKolo's Avatar
    Sep 2015
    POLAND
    here u go pass pm
  3. The Following User Says Thank You to takiKolo For This Useful Post:
    mm04kk (8th October, 2019)
    Germany
    Thank you very much I will try the file and give an Report.
    Thanks.
    Germany
    its an .mod file can i write it direktly over KESS to the car?
    Kind regards.
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Quote Originally Posted by mm04kk View Post
    Kind regards.
    if you have it read by kess, then yes...
    ksuite will calculate and correct checksum...
    When I help you press Thanks and Reputation...
  7. The Following User Says Thank You to figani For This Useful Post:
    mm04kk (9th October, 2019)
  8. #6
    Germany
    i have written the file today and i have driven about 50KM on Highway now the Engine Light dont blinking on Highway but, the Light is all the time on after the writting it dont goes off and no DTC is stored on the ECU. What can I do now? thank you
    Kind regards.
  9. #7
    Germany
    Thanks for the Help!!! The DTC Light went off Today herself and dont come on again. The Car works very fine no smoke and full Power. Thank you
