Uec,rec etc
Corsa D 2007 1.7d
original ECU is faulty after water ingress
I swapped these parts from other Corsa same year and engine
Key with PCF7941
ECU
BCM
Cluster
Steering Column
and disconected the info display and the radio
Central locking work OK with the key
but immo still blink and engine wont crank
Is there other module that must be swapped?
Uec,rec etc
Manta1600 (8th October, 2019)
has it had flat battery or been cranked on low voltage , common issue on this year of corsa d , if so may need pin code resetting in each unit and bcm reset
I don't know the story of new parts they are from scrap yard so everiting is possible
My tools can read the pin code only from the info display so I can't read the pin code for the new parts because info display missing - is it possible to read code from new speedo?
or maybe is better to make immo off on the new ECU and use with old parts?
You need airbag module its part of immo system
Best way is to resset engine ecu and code into original parts
Ashraf6119 (19th October, 2019), Manta1600 (8th October, 2019)
Lately with none stop rain most corsa ECU have been damaged with water I usually keep well out of corsa cars....
Manta1600 (9th October, 2019)
If you have the original pin code for this vehicle than go in to Airbag Model and reset the module and than reprogram it with the donner ECU pin code and you should be fine to start this vehicle...........
Thanks Ash
Oh yes if my post was helpful than Please don't forget to press the Magic word Thanks
Manta1600 (19th October, 2019)
