Page 1 of 4 1234 LastLast
Results 1 to 15 of 46
    auto techniek's Avatar
    Mar 2017
    Default VVDI BMW Reviews
    VVDI BMW is on the markt
    Anyone has got one?
    Any reviews what the tool can do?
    May 2013
    As found on the internet....
    What's the difference between VVDI2 BMW and VVDI BMW?
    Vvdi for bmw has possibility for coding and changing cars vo and retrofit options.
    vvdi bmw not only for locksmith, it has functions of coding and programming and much more.
    Vvdi for bmw has possibility for manual coding and changing cars vo (vehicle order ) , emergency flash and retrofit options
    What does the VVDI BMW do that the VVDI2 to does not?
    It has functions of coding and programming and much more
    Coding and programming enabled?
    vvdi bmw not only for locksmith, but it has functions of coding and programming and much more (such as change vehicle order and emergency flash and manual coding ….)
    Easy to use?
    For people who already is familiar with Bmw this tool is a mix of of Esys and Vvdi. Very easy, very powerful and quite useful.
    Parameters:
    Working temperature: -20-70°C (-4-158°F)
    Storage temperature: -40-80°C (-40185°F)
    Product size: 146*85*33mm
    Packing size:355*283*87
    Host net weight: 0.23kg
    VVDI BMW 1.4.2 released notes:
    Date: 2019-09-20
    Firmware: Require VVDI BMW firmware V1.4.2
    BMW V1.0.0
    1. E-Series programming, coding, DTCs
    1). Support autodetect car chassis
    2). Support scan all car units
    3). Support calculate all configuration units
    4). Support read/write car configuration(FA)
    5). Support input HW/ZB number to programming
    6). Support calculate default coding from FA
    7). Support edit detail coding information, change car config
    8). Support many languages DTC code
    2. F-Series programming, coding, DTCs
    2). Support read/write car configuration(FA)
    3). Support calculate programming files from unit, car, whole database
    4). Support calculate default coding from FA
    5). Support edit detail coding information, change car config
    6). Support detail special function list from coding
    7). Support many languages DTC code
    3. CAS1/CAS2/CAS3/CAS3+/CAS3++ISTAP OBD key learning
    1). Support read key information, write key information
    2). Support key learning
    3). Support read/write EEPROM
    4). Support read ECU/gearbox synchronize codes
    5). Support write ECU/gearbox synchronize codes
    6). Support synchronize ECU and CAS
    7). Support synchronize CAS and ELV
    8). Support read ISN via OBDII
    9). Support reset KM via OBDII
    10). Support disable key/enable key
    4. CAS4(1L15Y)/CAS4+(5M48H) OBD key learning
    1). Support read CAS encrypt key via OBDII
    2). Support key learning via programmer and via ignition switch
    3). Support disable key/enable key
    4). Support erase key position
    5). Support reset KM via OBDII
    6). Support read ISN via OBDII
    7). Support backup/restore coding
    8). Support update original CAS4 file
    5. FEM/BDC OBD key learning
    1). Support read FEM/BDC encrypt key via OBDII
    8). Support exchange used FEM/BDC
    9). Support close/open transport mode
    10). Support reset ECU lock
    11). Support switch on ignition without working key
    6. CAS EEPROM dump key learning
    1). Support EWS1, EWS2, EWS3, EWS4, CAS1(0K50E), CAS2(2K79X), CAS3(0L01Y), CAS3+(0L15Y), CAS3++ISTAP(0L15Y, 0M23S)
    2). Support prepare dealer key via programmer
    4). Support read ISN from working key
    7. 8HP Gearbox renew
    1). Support clear ISN in 8HP gearbox
    2). Support backup/restore coding
    3). Support reset adaptation information
    8. Read synchronize code from E-Series ECU: Support MEV9N46L, MSV70, MSS60, MS450, N62 etc
    9. Read E-Series/F-Series ECU ISN via OBDII
    1). Support MSV80, MSV801, MSD80, MSD81, MSD802, MSD812, MSD851
    2). Support MED17xx/MVD17xx/MEVD17xx/MV1722
    3). Support MED172/MEV17N46/ME17N45
    4). Support MEVD172Y/MEVD172/MEVD1725/B38/X63TU
    10. Support exchange ECU and CAS
    1). Support write ECU ISN via OBDII
    2). Support write ECU VIN via OBDII
    3). Support change ECU ISN and VIN with EEPROM dump
    4). Support change CAS1/CAS2/CAS3/CAS4 ISN and VIN with EEPROM dump
    11. CAS repair(OBD&EEPROM)
    1). Support repair ISTAP CAS
    2). Support repair CAS EEPROM(Service mode EEPROM), you can start engine after repair the file(CAS1,CAS2,CAS3,CAS3+,CAS3++ISTAP)
    12. CAS3+/CAS4+ lost all dump file support restore ISN and VIN
    1). Support CAS3+(1L15Y) encrypt version
    2). Support CAS3++(ISTAP) version
    3). Support CAS4+(5M48H) version
    13. File KM calibration
    2). Support CAS1(0K50E), CAS2(2K79X), CAS3(0L01Y), CAS3+(0L15Y, 0M23S)
    3). Support CAS4(1L15Y), CAS4(5M48H, 1N35H)
    4). Support E-Series dashboard EEPROM(M35080)
    5). Support F-Series dashboard EEPROM(35160, 35128)
    14. Unlock HITAG2 key: Support lock hitag2 key made from BMW TOOL via programmer
    15. EWS3/EWS4 can read EEPROM, write EEPROM via CAS PLUG
    2). Support MED17xx / MVD17xx / MEVD17xx / MV1722
    3). Supports MED172 / MEV17N46 / ME17N45
    4). Support MEVD172Y / MEVD172 / MEVD1725 / B38 / X63TU
    Are the same engine control units as before.
    EDC17CP02 is missing and other BMW engine control units are missing.
    Why should you buy this device ???
    Actually only coding and programming was added. But what exactly can be done with ESYS?
    Mar 2017
    This tool is a few weeks on the market and nobody know what is can do.
    No reviews
    No video's
    Nothing. This is a very bad marketing.
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by auto techniek View Post
    No reviews
    No video's
    No, the tool is not available yet. Only preorder started so you can buy it.
  6. The Following User Says Thank You to p1et For This Useful Post:
    Maartinj (22nd October, 2019)
    No reviews
    No video's
    why not buying it and test what it can do for your self???
    Maybe xhorse only remove ticket vvdi2 and put blue bmw tool ticket and chenge frimware in mcu will soon someone compare this two pcb
    I hope this too will be good in future!
  9. The Following User Says Thank You to Brat For This Useful Post:
    sniegavirs (22nd October, 2019)
  10. #8
    May 2018
    Got the tool and for now I did two keys - one for E63 CAS2 and second for E87 CAS2. Both without problem, 3-4 minutes job. There is a problem with reading FA from cars with CAS2 - it can't do this, but i think they will fix it soon, because more people wrote about this problem. Also, after loading dump from EWS3 it shows that mileage is 0km - of course not so big problem, because AK90 is best for EWS units.
    Update:
    - Can't read ISN from E-series ECU's.
  11. #9
    Lithuania , PNV
    Tried code airbag module on f15 17year read coding ok but recode unsuccessful With e-sys recode without problems
  12. #10
    Jun 2019
    Quote Originally Posted by MIKUr1 View Post
    Update:
    Almost any tool out there can do cas 2.
    if it can downgrade all cas3+ istap version without problems then and get isn through obd it might be worth looking in to but for now i will wait reviews from others.
  13. #11
    Quote Originally Posted by Staafonline View Post
    YES, let others be your ginnypic! let them wast money!
  14. #12
    Oct 2015
    i have it. what i've tested so far on vvdi bmw v1.5.0 with 1.3.0 database:
    -make dealer key from cas4 eeprom - no ( sw bug- app crash)
    -add key via obd on cas2 - ok
    -coding on F series - no (same thing - app crash )
    -make dealer key from ews4 eeprom- ok
    -coding on e60/e60 - no (can't read FA/VO from cas)
    -change cas3 km in eeprom file - ok
    -change km in clsuter 35080 eeprom dump -ok
    -reading dtc E series - works in any other language besides engilsh just for a sec than somehow they dissaper from screen
  15. #13
    Oct 2016
    i have it and coding F series and E series cars works 9/10 times so it is ok, tried unlock cas 4 on F10 and it worked no problem , tried updating a zbe on F10 just to see if it works and it did , did a few software updade on modules E60 and it was ok .
    i have V 1.6.0 i think it has a lot of potential .
  16. #14
    celje, slovenia
    Hello
    has anyone tryed correcting milage on cas 4, fem and bdc vith this tool?
  17. #15
    ASCM's Avatar
    Oct 2018
    Hello does anyone tried to make egs 6hp reset and adapt for E serie?
    Sent from my SM-J415F using Tapatalk
