Results 1 to 8 of 8
    Jun 2016
    Default Lambda OFF me7.5
    Hello i need lambda off for audi a4b6 me7.5 0261208524 and dtc for heater second oxygen lambda P1118 thnaks.
    CaptainHaka's Avatar
    Feb 2019
    BY
    Hi! you file////
    Jun 2016
    Not found idle rpm up and down and no lambda regulation.
    Oct 2018
    hi lamda off chk ok
    test and repli
    thnx .....................
    Jun 2016
    Dump is the same to original
    Oct 2018
    Hi I used your dump and dug out a lamda sensor, type test and let me know, I didn't understand you my English is bad
    the dump is yours from your car, don't be afraid
  7. The Following User Says Thank You to tothzsolt For This Useful Post:
    gilbert250 (14th October, 2019)
    Jun 2016
    I dont undestand
    Jun 2016
    Thanks for all i allredy solved my problem with lambda.
