Results 1 to 15 of 16
    Jan 2019
    Default Map Check 335D E92
    Hello Friends,
    I have a 335D E92 with Tune, Agr and DPF Off but every time when I am full throttle and reaching 220 Km/h the car is going in to limp mode, than I musst switch the ignition off and on and everything is ok.
    Can somebody check my File plese
    https://mega.nz/#F!lFNljSbT!w44v1cYlBvczoRu0XRwwQw
    This is The Link for the File and SW Info.
    Thank you very much!
    a500tut's Avatar
    Jun 2017
    Belarus
    Quote Originally Posted by AudiA53xxx View Post
    Hello Friends,
    If this solution does not solve your problem, then you will need to completely make a new file.
    If I helped you, click thanks and reputation
    Jun 2018
    Bulgariq
    Default test
    Hello Friends,
    pass- pm
    Jan 2017
    Belgium
    Here you go, stage 2 file 385hp 800nm dyno tested.
    Allot of tuners dont know how to tune these good so watch out with the file you test
    With r90 and 50d rail sensor 420hp 1000nm possible.
    Pass in pm
  5. The Following User Says Thank You to msmotorsport For This Useful Post:
    AudiA53xxx (17th October, 2019)
    Jan 2019
    Quote Originally Posted by msmotorsport View Post
    Pass in pm
    Hey mate this donīt match with my Orig file Railpresure and other Maps dont match
    This is my Orig File maybe this will Help
    https://mega.nz/#!8McnAISC!qmUgurYUU...O7UioD-IAhzJdY
    Jan 2017
    Belgium
    It matches mate, rail pressure maps are all the same thats why it looks like it doesnt match.
    Write the file, everything will be okay
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    Nice tuners. Guy say he get limp mod,everyone fix problems, but no one ask what faults he have .... LOL
    Chiptunning / EGR / DPF / FAP / DTC / FLAPS / Adblue / ETC.... CUSTOM SERVICE / FILE SERVICE / 24/7 Support
  9. The Following User Says Thank You to Ignasvw For This Useful Post:
    kinketotua (17th October, 2019)
  10. #8
    rfernandes's Avatar
    Jun 2018
    portugal
    Pass in pm
    more than 800nm you need to upgrade your gearbox
  11. #9
    Jan 2019
    Quote Originally Posted by Ignasvw View Post
    Dere ist no engine light or something like that, just when I read with Inpa it says error 428B
    Gesendet von iPhone mit Tapatalk
  12. #10
    Jan 2019
    Is it AGR and DPF OFF?
  13. #11
    Jan 2017
    Belgium
    This problem happens allot with coffetuners files, bad tuning of turbo maps. Wastegate not adjusted for the more air so turbo starts to overboost.
    Wastegate in my file is adjusted to open more to control overboost .
  14. #12
    Jan 2017
    Belgium
    Quote Originally Posted by rfernandes View Post
    No its not, these 6hp28 handle 1000nm without problem. i have done many with r90, 50d rail and turbosystem ballbearing hybrid running over 1000nm and +460hp
  15. #13
    Jan 2017
    Belgium
    Yes, empty your message folder
  16. The Following User Says Thank You to msmotorsport For This Useful Post:
    AudiA53xxx (18th October, 2019)
  17. #14
    Jan 2019
    Ok, I did empty it but didn‘t get any message.
    I‘ll try the file as soon as possible and will report if its working mate
  18. #15
    Jan 2019
    Pass in pm
    Thank you very much for this File mate no limp mode and very powerful
