use the search and you will become happy man.
Hi, I have a 2007 Audi A3 with VDO instrument panel.
The instrument panel is completely dead and obviously the engine does not start.
No work has been done on the instrument panel (such as adjusting the kilometers).
according to you, the problem is in the flash (micronas) and eeprom?
Thanks in advance
chris781 (11th October, 2019)
99,9 flash problem.
kobelco (11th October, 2019)
Hello, after many attempts I was able to read the Micronas with Xprog.
Can anyone tell me if the flash is compromised and repair it?
Thanks in advance
Report....
kobelco (16th October, 2019)
Edited: you are right, I posted the same file, my error. Sorry for that.
check your inbox
kobelco (17th October, 2019)
Hello, I tried the instrument panel, in the display on the right is written DEF and there are several lights on (airbag, steering, abs ...).
dtc, control unit fault
Some idea?
Dash death after scnanner or death after calibratio km, maybe aku bad?
No operation was made on the instrument panel, suddenly he died.
Now I have the car available, I do tests and I update you.
Never attempt Micronas cluster without proper tools!!! What tools have you got?
