Results 1 to 5 of 5
    Dec 2017
    South Africs
    Default Help identifying heat paste/silicone
    Hello everyone.
    Anyone know what the white heat paste/silicone is called in the pic?
    Ive seen it used on many ecu's to bond the pcb to the aluminium housing part of the ecu cover.
    narkeleptk's Avatar
    May 2017
    USA
    Its probably some in house mix for the ecu manufacturer. I usually just use thermal grease when replacing it. Like this https://tinyurl.com/y3g85tmz
    Dec 2017
    South Africs
    thanx for your reply, only problem is the thermal grease wont "glue" the pcb to the housing and thats my problem because there is about a 5mm gap between the pcb and the housing without the "glue"
    Meat-Head's Avatar
    Confused, go to local computer shop, nothing new, heatsink GLUE beleive it does NOT come off again
    https://www.amazon.com/MG-Chemicals-.../dp/B06XDL1NRQ
  5. The Following User Says Thank You to Meat-Head For This Useful Post:
    narkeleptk (18th October, 2019)
    narkeleptk's Avatar
    May 2017
    USA
    Quote Originally Posted by Limitlesstuning View Post
    "Thermal adhesive" is what you would want to search for then but re you sure there is nothing else helping gold the pcb in place like some nylon spaces?
