Megane 3 (2011) Blank Dashboard
Results 1 to 8 of 8
    Oct 2019
    Downloads
    Uploads
    Default Megane 3 (2011) Blank Dashboard
    Got a Megane 3 1.5dci from 2011 with 151000km
    The speedometer when back after i connected a odb2 to pair with the phone via Bluetooth.
    Recon that i might've corrupted data as the dashboard/speedometer went all black.
    Got a carprog tool but i don't have any dump files.
    Can any one help me out?
    Many thanks
    mariuszko's Avatar
    Sep 2015
    11
    Downloads
    Uploads
    disconnect the battery for 1 minute
    brend's Avatar
    Oct 2015
    Same where
    2,057
    Downloads
    65
    Uploads
    If not start enymore!
    In bench and bdm away flash/eep.
    About information for ask ...........
    http://www.digital-kaos.co.uk/forums/announcement.php?f=174&a=32
    And for enjoy life better read rules............
    Oct 2019
    Downloads
    Uploads
    Quote Originally Posted by mariuszko View Post
    Thanks for your fast reply.
    Already tried it.
    Checked fuses also.
    Cheers
    Oct 2019
    Downloads
    Uploads
    Quote Originally Posted by brend View Post
    thank you for you reply
    It does start, i am even able to run it as engine, ligths, blinkers, GPS, radio, etc are up and running... just the damm dasboard/speedometer appears off (not turning on)
    I've checked all standard fuses under the dashboard and even the ones on the engine compartment... they all seem ok.
    Regarding flash/eeprom, got no files to do it... kind of lost there.
    Oct 2019
    Downloads
    Uploads
    Anyone with other ideas?
    May 2017
    23
    Downloads
    Uploads
    find good flash and flash instrument cluster with abrites by obd2
    Oct 2019
    Downloads
    Uploads
    Where could i get such flash?
    all i got is the bin that i've attached to this message
