Results 1 to 7 of 7
    Mar 2019
    Italy
    Default VW Tiguan DPF OFF Problems DTC
    Hi everyone, i have removed the dpf on my tiguan, but the ecu show me some dtc error and i can't shutdown they with some program.
    The dtc error are these:
    0134 Engine Control Unit (Abs)
    0134 Engine Control Unit (Strumentation)
    0134 Engine Control Unit (Clima-Climatronic)
    0134 Engine Control Unit (Parking Brake)
    p2002 dpf filter efficiency lower limit bank1
    p2002 particulate trap efficiency below the threshold bank1
    I have the downpipe with all the sensor connected...
    https://mega.nz/#!G6BBnAxS!HJ5dZTKbA...jdo3nX4Tv5D89g DPF OFF
    https://mega.nz/#!CuQjmKiD!wgQ8KvF5J...BDgBVZkNQgoh7o ORI
    Someone can help me?
    Oct 2018
    send ecu type?
    Oct 2018
    hello in fashion flash file they weren't good chaksum 4 piecesnot ok, i got you right now they are good try again to type fashion flash file and you will be ok
  4. The Following User Says Thank You to tothzsolt For This Useful Post:
    Simone Pagano (18th October, 2019)
    Mar 2019
    Italy
    ok i'll try and let you know.
    Thank You very much
    Mar 2019
    Italy
    Same problem as before, after about 70 km, the lights come on again ...
    Sep 2013
    lights without DTC?
    WinOLS5, custom files for ECU DCU
    Mar 2019
    Italy
    Turns on the engine light with these dtc's.
    0134 Engine Control Unit (Climate-Climatronic)
    And continuing to drive with these errors turns on that of the dpf and then that of the flashing glow plugs that sends the car in protection.
