If there are no errors you should deal with the parameters and see what is wrong there, what tool did you read the errors?
Hello everyone,
I have a VW caddy 1.6 TDI 2011 and I have a problem with it. Problem is the car can not go more than 2800 RPM during moving and without moving. All the time can not go more than 2800RPM. I have make diagnostic and no error code present. All the time I have no error code present. I have check every fuse and all are OK. When I start the car for about 30 second or 1 minute everything is OK and RPM go 5500RPM but after 30 second or 1 minute RPM go down and not go more than 2800RPM. Any idea with this problem, or anyone have same experience with this problem
I jave try with Delphi diagnostic and Launch diagnostic.
Any idea ??
Check if it has a clutch switch.
Now I make a test again with car now I have this error : P261A (Coolant Pump B, Open Circuit). I think this error can make car limp mode. I have change this pump and this pump work but the error is the same. So can anyone remove this pump from ECU flash ? I have try to remove DTC OFF (to remove this error), but no succes. So anyone can help me ????
Any idea ???
I solve the problem, I remove EGR from flash dump and remove the error from dump. Now everything is OK
Meat-Head (15th October, 2019)
I would have also said EGR. Sometimes trying a blanking plate can circle out the problem. Only issue in VAG common rail engines, the EGR is behind the engine and very hard to get to.
Anyway nice job
