Results 1 to 10 of 10
    unnamed11112007's Avatar
    Aug 2015
    Belarus Molodechno
    Default Volvo SID803A DPF OFF
    Hi mates
    need DPF OFF for VOLVO V50
    SID803A
    ----------> volvo v50 original.rar
    tell me thanks I will be very happy
    Oct 2018
    test and report
    thnx...........................
    dpf off chk ok
  3. The Following User Says Thank You to tothzsolt For This Useful Post:
    unnamed11112007 (14th October, 2019)
    please try and report
  5. The Following User Says Thank You to vaggelis00 For This Useful Post:
  6. #4
    Aug 2015
    Belarus Molodechno
    Quote Originally Posted by tothzsolt View Post
    test and report
    dpf off chk ok
    ADS no good solution, not work
    Aug 2015
    Belarus Molodechno
    Quote Originally Posted by vaggelis00 View Post
    thx, but not work
  8. #6
    Oct 2018
    no ads solution,
    how is it wrong what is wrong?
  9. #7
    Aug 2015
    Belarus Molodechno
    no ads solution,
    white smoke, diesel in oil, DTC C301
  10. #8
    Oct 2018
    when did you get white smoke in your car ??? did you already have white smoke in your car before you typed a modi flash file for dpf off ????
  11. #9
    Oct 2018
    white smoke in the exhaust it's water that's why it's white smoke, it has nothing to do with dpf. check the engine head first gasket if the gasket is good then the engine head has burst somewhere
    and check that the water from the car is missing
  12. #10
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    test and report
    dpf off chk ok
    Your solution is wrong. Dpf main switch is active
    Chiptunning / EGR / DPF / FAP / DTC / FLAPS / Adblue / ETC.... CUSTOM SERVICE / FILE SERVICE / 24/7 Support
