Any mechanic problem?save mode?any dtc??
Last diagnostic apear dtc 0000 with delphi100
Use other diagnostic, in many cars Delphi can't show the correct error number...
safety mode maybe not because when it arrives around 140kmh it blocks the speed either in 5 gear or 4gear. My file have any problem?
anybody check if speedlimiter is ON ?
On this ecu egr off must be unplug???
Why are deleted:
P0004 - Fuel Volume Regulator Control Circuit High
P0504 - Brake Switch Circuit 'A' / 'B' Correlation
BTW, this manier of deleting errors gives P0000 output in diag and not remove the consequences of them.
Regards!
