Page 3 of 24 FirstFirst 1234567813 ... LastLast
Results 31 to 45 of 355
  1. #31
    DK Veteran manocao's Avatar
    links are working right from here http://www.digital-kaos.co.uk/forums...manocao-77948/
    dont copy and paste on adress bar cos address will be wrong
    click on link
    please other try and tell
  2. #32
    E. Yorks. UK
    Quote Originally Posted by mattydr67 View Post
    For UNIDIAG or FIATECUSCAN you can use a simple KKL interface (VAGCOM 409.1).
    Carbrain is profesional tool and works with it dedicated interface.
    Because you are new take a kkl Vagcom from ebay, there cheap, and you can try.
    Hi mattydr67
    Yes I am new to this forum but not exactly new to cars as I have been a mechanic for the better part of the last 35 years. although in agriculture for the last 27.
    I have looked into FiatECUscan but at the moment this does not seem to cover the ECU fitted to the Fiat Punto MK1 GT (1372 cc Petrol engine) with Bosch Motronic M2.7 MPI system.
    I have not looked at the Unidiag yet.
    By the way this is my sons pet car which took us 3 years to build.
    I drive a 2003 Astra which I use Opcom on.
    Cheers for your suggestions so far.
  3. #33
    Member bmotor60's Avatar
    added:
    visa 1.83 by manocao for uniscan/euroscan interface
    installs in C:\VISA_183, english language by default (vs rusian), desktop and start menu links, coverage file
    DOS program
  5. #35
    Default Vag-com 409
    Just got my interface. The shareware VAG-COM 409.1 that came with it is working great. Guess it is time to get the registered version.
  6. #36
    mexanico1971's Avatar
    portugal
    is anyone try to work id (AK 500) epron programer? here in portugal is unknow , can it do remap by obd2 cable! like bdm 100 it?s possible to adpat a obd2 cable to do the remap without take out the ecu fron the car ?
    my regards to alll !
  7. #37
    Hello
    Someone has a software for Motronic M 1.5.5 , for GM and Opel cars .
    Opel-com and AB-com doesn?t work with ASTRA year 2004, engine C18YE ( KWP2000) protocol, only falty code is ready.
    Thanks for the reply.
  8. #38
    added uniscan visa 1.83
    new thread with full info and software here http://www.digital-kaos.co.uk/forums...o-u-all-84463/
  9. #39
    Member jimdollar's Avatar
    Oct 2008
    Default Opcom
    I updated my Chinese clone Opcom with the 090821d from manacao, works great, I had previously tried updating a different version and got the usual relay clicking problem in the Opcom unit, this version sorted it all out. thanks Manacao, Jim
  10. #40
    Quote Originally Posted by jo?o antonio View Post
    Hello
    other software for motronic 1.5.5 is:
    -scanmaster or vauxcheck for elm327 -> c18ye not supported
    -unidiag -> for alfa and fiat motronic 1.5.5
    -www.fiatecuscan.net
    in any of these work, probably only dtc reading/erasing would be available
    you could try other motronic 1.5.5 similar models to c18ye with opcom
    edit: attached unidiag 0.3.3.1 by manocao
  11. #41
    added: build your own ALDL interface
    -GM 8192/160 Baud ALDL Interface
    -ALDL OBD1 OBD cable OBDI OBD2 engine codes
    -attached file
  12. #42
    Oct 2008
    On Earth
    Quote Originally Posted by Itsme View Post
    Hi mattydr67
    Sorry that I said "NEW" it was correct NEWBIE but you'll not be mad about that.
    Now I'm not at my laptop and I cannot check if it's so, I mean if your Palio engine can be diagnostic by the AlfaDiag but you ca try it.
    Good luck
  13. #43
    for those who ask over and over again
    http://www.digital-kaos.co.uk/forums...terface-84826/
  14. #44
    I have year 1997 Opel Vectra-B with engine X16XEL. What software and hardware are best for diagnose and observe my car ECU.
  15. #45
    too busy to use search and read threads? uhh?
    cheapest (only engine pin7 or add switch) = vag-com 409.1 blue cable + mocpo (opcom demo with all measuring blocks)
    best = op-com v2 updated to fw v1.39 interface + 090821d
    info and software
